Fog light connector?
2.0L • TURBO • 4WD • AUTOMATIC
BHAMDOC1
  • 423 POSTS
looking for the passenger side fog light harness but cannot find it. Can you see where it is coming from and whether it shares a bundle before it splits? I see the other side along with the parking sensors connector, but nothing on the passenger. I am sure I disconnected it.
Aug 27, 2026 at 11:15 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Check the VIN-based equipment information and the correct owner's manual before searching further for a missing harness. Confirm whether the openings or lamps belong to the original bumper arrangement or an aftermarket replacement. If factory fog lamps are confirmed, use the matching wiring diagram to identify the connectors and inspect for removed or damaged wiring. If they were never fitted, adding them is a retrofit that needs compatible wiring and controls. Do not borrow connections from parking sensors or the outside-temperature sensor. The first useful answer may simply be that this car was not built with that equipment. Confirming the build specification prevents buying a harness to fix something that was never installed.
Guidance references and applicability
Audi: VIN-based owner manual https://ownersmanual.audi.com/home/en_US Official equipment and operation reference. A manual may describe optional equipment; confirm the vehicle's build information before ordering wiring or lamps.
Read the replies · Discussion summary and reported outcome
  • 55,711 POSTS
The right passenger fog lead is the longer branch. It routes across the lower front of the vehicle, behind/under the center grille area, toward the passenger fog lamp. On cars with front parking sensors, it runs in essentially the same area as the front parking sensor harness, so that's the bundle I would follow first.
Aug 29, 2026 at 8:31 AM
BHAMDOC1
  • 423 POSTS
turned out there are no connectors to them I guess it didn't come with it. as there are no wires on either side. one was for the parking sensors, and the other for ambient temp sensor
Aug 29, 2026 at 12:56 PM
  • 55,711 POSTS
Okay, that makes sense.
Aug 30, 2026 at 10:18 AM
Discussion summary
The owner looked for a front fog-lamp connector on a 2016 Audi. After checking both sides, the owner found no matching wiring and concluded that the vehicle might not have been equipped with those lamps. Factory equipment information was not supplied.
Reported outcome: The owner suspected the car lacked factory fog-lamp wiring; this was not independently confirmed.
The original equipment list and any bumper modifications were not established.
Read the original discussion
