I changed the engine, torque converter and fly wheel. Two weeks later the fly wheel broke again.
May 15, 2016 at 3:28 PM
✓Experienced Mechanic
Very important to use new bolts and torque in correct order and to the correct torque specs. Was this done?
May 15, 2016 at 11:40 PM
HMAC300
you probably have a starter problem of not aligning properly or flywheel may have been cracked or there is an alignment problem with converter to flywheel.
