Flushing engine coolant
114,000 MILES • 5.7L • V8 • 2WD
JUNIOR AGUIRRE
  • 13 POSTS
I changed my alternator flushed the coolant and only added one gallon of pure coolant. Ran the car for two hundred miles could I of damaged the engine? Engine did not overheat.
Jul 27, 2018 at 3:54 PM
Good morning.
Coolant should never be added with 100% coolant. It needs to mixed with water. It should be 50-50 mix. If you use one gallon of pure coolant, add water and you will have two gallons of 50-50 mix.
Using the pure will cause the engine to run too cool and the engine will not reach normal operating temperature. It will eventually set a code for efficiency.
Jul 27, 2018 at 11:11 PM
STEVE W.
  • 15,418 POSTS
Well you did flush the system and likely there was quite a bit of water left in the block depending on how you did the flush. That would still make it low but it may not have hurt it. The system holds 14+ quarts total.
May being the operative word, How did you flush it out? How did you drain it?
The only real way to know would be to top it up with coolant and run a pressure test on the system to see if it has any internal leaks. Then see how it behaves once it is full. I would also change the oil as it likely was running hotter than it should.
Jul 28, 2018 at 8:48 PM
JUNIOR AGUIRRE
  • 13 POSTS
I just unscrewed the plug from the bottom of the radiator and to be honest I did not even add the full gallon now that I remember I just filled the tank up.
Jul 29, 2018 at 2:26 AM
Did you bleed the system of all air? There is a bleed screw at the upper hose to the engine that you open while filling to allow the air to escape.
Jul 29, 2018 at 2:53 AM
JUNIOR AGUIRRE
  • 13 POSTS
I did not smh.
Jul 29, 2018 at 3:01 AM
JUNIOR AGUIRRE
  • 13 POSTS
Could that cause some damage?
Jul 29, 2018 at 3:02 AM
Not at this time. Like I said before, it should be delulted to 50-50 not pure 100% coolant.
Change it out to the proper solution. Over time, you can damage the motor.
Jul 29, 2018 at 3:11 AM
JUNIOR AGUIRRE
  • 13 POSTS
Okay, I did run it for about two hundred miles.
Jul 29, 2018 at 3:51 AM
Thats okay.
As long as the engine light did not come back, you are good. just change it back out ASAP.
Jul 29, 2018 at 3:53 AM
JUNIOR AGUIRRE
  • 13 POSTS
What I did was add water to it. Do I have to flush all over again?
Jul 29, 2018 at 4:04 AM
How much water?
Jul 29, 2018 at 4:06 AM
JUNIOR AGUIRRE
  • 13 POSTS
I did not add the full bottle of coolant that day, just what fit in the tank then the rest of the coolant that was left in the gallon I added water to it when I realized it was going to need more.
Jul 29, 2018 at 4:09 AM
Okay, then it sounds like you are good.
Jul 29, 2018 at 4:52 AM
JUNIOR AGUIRRE
  • 13 POSTS
But, I did run it for two hundred miles until I noticed.
Jul 29, 2018 at 6:27 AM
I understand that. I posted that you were good, but it changed out so you have the proper mix.
Jul 29, 2018 at 6:35 AM
JUNIOR AGUIRRE
  • 13 POSTS
Lol, okay.
Jul 29, 2018 at 6:51 AM
JUNIOR AGUIRRE
  • 13 POSTS
Just worried man.
Just do the change and forget about it.
Jul 29, 2018 at 7:13 AM
STEVE W.
  • 15,418 POSTS
Now that you have topped it off how is it acting? From what you have said you ran it with about a 3/4 - one gallon low on coolant. That may have been enough to save it. I would still be watching close.
Jul 29, 2018 at 7:15 AM
JUNIOR AGUIRRE
  • 13 POSTS
It runs good never over heated, but I think I here a little noise in the engine but it might just be me freaking out.
Jul 29, 2018 at 7:34 AM
  • 55,746 POSTS
It could just need an oil change. Here is a guide to help:
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Aug 1, 2018 at 10:49 AM
