I need to replace front, back differential fluid and transfer case fluid
102,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
ZEMORZEMOR
  • 486 POSTS
I need to replace front, back differential fluid and transfer case fluid also.
what type of fluid those three components need? do I need to add anti slip additive to the differentials?
Thank you
Dec 18, 2016 at 11:34 PM
STEVE W.
  • 15,420 POSTS
Front differential API GL 5, 75w-90 synthetic gear oil.
Transfer case - ATF +4 or equivalent.
Rear differential - API GL 5, 75w-90 synthetic gear oil.
Without the VIN we cannot tell if it has a Trac-Lok limited slip.
Dec 19, 2016 at 12:12 AM
ZEMORZEMOR
  • 486 POSTS
VIN 1D7HU18236S615793
THE rear differential was low so i added 75w140. is it ok to put 5w140 instead of 75w90?
Dec 19, 2016 at 11:31 AM
SATURNTECH9
  • 30,868 POSTS
No you need put the correct weight oil in.
Dec 19, 2016 at 2:27 PM
STEVE W.
  • 15,420 POSTS
Going by the VIN Dodge says you don't have Trac-Lok so no additive required. But If you bought it used, verify that as you never know if that was changed at a later date.
You don't really want to mix lubes in differentials. They are under a lot of stress and mixed lubes can cause problems.
Dec 19, 2016 at 9:56 PM
ZEMORZEMOR
  • 486 POSTS
the differentials oil and transfer case never been changed.so do i need to do?
Dec 19, 2016 at 11:46 PM
STEVE W.
  • 15,420 POSTS
With 102,000 miles on them they are long overdue.
Dec 20, 2016 at 3:14 AM
ZEMORZEMOR
  • 486 POSTS
can you please tell me the capacity and the torque spec for the differential bolts and the transfer case
Dec 20, 2016 at 1:36 PM
