Fluid leak
156,000 MILES • 3.8L • V8 • 2WD • AUTOMATIC
PAM GROFF
Fluid drains from the radiator into the oil pan.
Dec 8, 2019 at 7:33 AM
PAM GROFF
What causes the above condition? Fluid draining into oil pan is coolant.
Dec 8, 2019 at 8:38 AM
SCGRANTURISMO
  • 4,897 POSTS
Usually if you have coolant mixing with the oil, or coolant getting into the oil pan this is a sign of a blown head gasket. It can also be caused by a cracked cylinder head or engine block, but these happening are far rarer than a blown head gasket. Here is a link below explaining what is going on:
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
You can also confirm a blown head gasket with a compression test.Here is a link explaining how to do that:
Please go through these guides and get back to us with what you find out. We can go from there.
Thanks,
Alex
2CarPros
Dec 8, 2019 at 9:14 AM
