Floor shifter?
1,000,000 MILES • V6 • 2WD • AUTOMATIC
RKUHN88
I have a plastic piece broken and can’t find a replacement for it. I don’t know what it’s called it’s shaped like a trigger with a little spring.
Sep 8, 2024 at 4:22 AM
  • 110,248 POSTS
I attached two pictures below. Could you take a look at them and let me know if the circled portion is what you are referring to?
Also, if those are incorrect, could you upload a picture of the part?
Sep 8, 2024 at 12:29 PM
RKUHN88
Yes, that’s it.
Sep 9, 2024 at 3:18 AM
  • 110,248 POSTS
The part isn't available separately. To get that part, you will need to get a different shift lever. The best thing to do would be to contact salvage yards.
The part is a shift paw. It prevents the shifter from moving when the shift release is let go.
Let me know if I can help in any way.
Sep 9, 2024 at 12:29 PM
RKUHN88
Do you have a part number? I’m going to get a 3D printer service to try and make it.
Sep 15, 2024 at 2:38 AM
  • 110,248 POSTS
I think that is a great idea. However, because of the model year, I don't have a part number. The manuals only provide the labor rates.
If you can, could you let me know if they are successful in making it for you? I'm interested in knowing.
Sep 15, 2024 at 11:39 AM
