I have a B2200 and I can start it and it will run for a second or two then the front overfill bowl I guess is what it is fills and overflows. it is right over the float bowl. I have taken the bowl out and checked the float and pin needle valve and look in good condition and vacuum lines are in good condition just put a new fuel pump on it and it run for one day. I drove it for about twenty minutes and after that it is having the same problem. i do not know what could cause this I am used to fuel injected engines.
Aug 7, 2017 at 5:27 AM
