Flooding issue?
37,000 MILES • 4.2L • V6 • 4WD • MANUAL
JACE KINCELL
  • 5 POSTS
I've been working on this vehicle for a few weeks now and can't figure it out. It will run for a while then it will flood while just sitting there idling, I've gone through the vacuum lines and capped off anything unnecessary. I've replaced the cap and rotor but still nothing. It runs and idles great but after about 10 to 20 minutes it floods.
Update: Just got it started again and it's now running like an old tractor. You can't let off the gas or it'll just stall.
Aug 31, 2023 at 2:46 AM
CJ MEDEVAC
  • 11,000 POSTS
Jace,
What kinda fuel pump are you using?
Carburetor brand and type?
I'm guessing this is a 258 and not a V-6 as in
your info above.
Something that might help a lot would be some
pics all over with the breather removed.
Maybe not so close up, but different views as to
maybe see it all.
Especially to include the carburetor.
Lot's of things could be modified over the past
38 years, sometimes I can spot an issue faster
than "digging for one in text"
Maybe we can get it all figured out!
----The Medic
Aug 31, 2023 at 11:31 AM
JACE KINCELL
  • 5 POSTS
Hey Medic yes, it is the strait 6 and not the v6 sorry about that.
I'm not currently home but I will take a few pictures when I get home.
It has a mechanical fuel pump.
I don't know much about the carb other than its a cheap one from Amazon.
Sep 1, 2023 at 2:42 AM
JACE KINCELL
  • 5 POSTS
Here's the photos:
Sep 1, 2023 at 6:02 AM
CJ MEDEVAC
  • 11,000 POSTS
It's not always a fast fix---but we try the best we can!
Some Jeep threads I've answered on here are over 100 posts long!
Maybe some more closer (not too close) pics around the
carburetor, intake manifold
(vacuum lines)
and maybe some around the distributor.
Do you have tools/ meters/ etc that you can use to correctly tune
your Jeep? Timing light/ dwell-tach/ vacuum gauge?
Do you know how to use them?
I have a couple of pics for you.
----The Medic
Sep 1, 2023 at 8:15 AM
JACE KINCELL
  • 5 POSTS
No, I don't have anything fancy just basic tools.
Sep 1, 2023 at 8:42 AM
  • 110,251 POSTS
I read through your post. CJ is the best one we have with the Jeeps. I have a question, Have you checked the float? The needle and seat in the carb may be sticking open allowing the float bowl to overfill and flooding the engine.
It's a thought. Also, is this something that just started? I've taken apart carbs and found dirt in the needle and seat that blocked it open, preventing the float from stopping the fuel from entering.
It's a thought. CJ, what are your thoughts on that idea?
Sep 3, 2023 at 2:37 PM
JACE KINCELL
  • 5 POSTS
Hi Joe, thanks for the idea.
I've thought about doing that, but I'm still trying to figure out carburetors on cars.
I'll just have to do it and learn the hard way.
Sep 3, 2023 at 11:16 PM
CJ MEDEVAC
  • 11,000 POSTS
All rightey!
I have to explain this like this unless you have magical powers!
I don't know if it's actually flooding or not (yes, it is possible
your needle and seat may be allowing too much fuel in, either
set wrong, or defective parts (bad needle and seat/ float with a
hole in it).
I usually save that stuff for last.
It may have a choke setting problem.
Nevertheless, Things must be set the best they can be to
make it want to run. Like correct adjustments and such.
It's not gonna want to run with it initially being cold.
You will not be able to adjust it wonderfully until it can
stumble it's way on up to operating temperature.
Then it can be adjusted!
Hopefully, no one has abused things like over tightening the
mix screws.
Neglected maintenance parts like spark plugs/ plug wires/
distributor cap/ etc. should be installed. Slinging in
unnecessary stuff in should be avoided.
A real biggie---don't start slinging in a bunch of fad crap
that your buddies recommend!
This exponentially compounds problems!
To do this correctly, you will need some meters/ gauges---it
is impossible to close enough by "ear". (this ain't a push
mower)
I answered a post in 2010 to aid a Jeep guy with his 304.
I used my 258 to talk him through getting his 304 to run.
There may be other things that might need to be addressed
in the thread,
If you'll concentrate on the 258 pics and text, this might
get it running better, then we might tweak things from there.
https://www.2carpros.com/questions/jeep-cj7-1985-jeep-cj7-stalls-when-hot
I had not been a member long back then, my grammar lacks at
times,
I use country boy lingo, and I had a different user name (it was
suggested that I change it) Years later, it's "locked" and
I cannot edit it.
"Vapor Lock" is a real thing, but if your fuel system is still using a
return line to the tank (3 port fuel filter)--it is doubtful you have
that issue at all!
Usually ignorant folks sling that term out there to make
themselves seem knowledgeable!
The tuning stuff you need can come from Amazon/
Yard Sales/ my favorite---Pawn shops (cheap) folks don't
even know what they are!
Let's see if my link helps! Report back with good news!
-----The Medic
Sep 4, 2023 at 12:45 PM
