Engine flooding
140,000 MILES
JONES ALMOND
After being driven and reaches operating temperature regardless of time it was driven, and turn off engine it is hard to start after fifteen to thirty. The only way to get it started again is to push accelerator to the floor and hold. I understand this signals computer to not inject gas.I don't know if there is any connection but the idling rpm fluctuate.
Dec 13, 2018 at 8:32 AM
  • 55,721 POSTS
This sounds like one of the injectors is shorting out which will cause the injector to go full on and flood the engine. Lets run the codes and test each injector. Here are two guides to help us get started:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
and
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
Cheers, Ken
Dec 15, 2018 at 2:47 AM
JONES ALMOND
Ken, thanks for your reply. Once an injector shorts out, does it stay shorted or can it be an intermittent problem?
Dec 26, 2018 at 9:34 AM
  • 55,721 POSTS
It can be intermittent.
Dec 27, 2018 at 9:13 AM
JONES ALMOND
Thanks for last reply. On 8/15/'18 when it was towed to an independent garage they replaced two injectors. I will have to ask if they checked the others for shorting. It is difficult to check the others and does it take special equipment?
Dec 28, 2018 at 4:52 AM
  • 55,721 POSTS
Not really here is a guide that will show them how.
Dec 29, 2018 at 2:58 AM
