Flickering headlights and flickering blue high beam indicator on dash?
154,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
BRUCEDUNCAN
  • 35 POSTS
Dear Al I am back. My name is Bruce Duncan. You gave me a ton of information on my 2003 Monte Carlo SS last year. No spark. I never found the problem after 4 months of on and off diag with you. The day I sold the car it started and it has been running for at least 6 months with the new owner.
Today is 1/10/26
I bought a 1996 S-10 pickup 4.3 liter and last night both headlights were flickering on and off.
The high beam indicator on the dash which is blue in color flickered along with the headlights.
When I got home and put the vehicle in park both headlights were still flickering on and off and then they worked good. Today the headlights worked o.k.
I was wondering if you could E-mail me a wiring diagram of the headlights. Especially the location of where the ground wire bolts to the frame or chassis. I suspect a partially broken wire or corroded ground terminal is my first thought.
What is the easiest way to check the ground circuit?
What do you think about my lights?
I also forgot to mention I have daytime running lights on this truck, only the headlights come on not the running lights.
Thanks Al your friend Bruce Duncan
Jan 10, 2026 at 9:13 AM
AL514
  • 5,692 POSTS
Hey there Bruce, I will grab those diagrams for you right now. The Daytime running lamp system has its own control module. Have you taken a voltage reading right at the Alternator stud? Since the head lamps are a high current draw, see if you have good charging system voltage with the head lamps on, that will load the electrical system. I would see what youre getting for voltage right at the headlamp connector as well.
I will get the wiring diagrams ready for, but checking for voltage drop when the circuit is loaded with the headlamps on, both on the positive and negative side to see if there are any connection issues on either leg. Pretty strange on the Monti Carlo,.
Jan 12, 2026 at 1:05 AM
AL514
  • 5,692 POSTS
Diagrams 1,2 are for the Sealed Beam headlamp bulb, diagrams 3,4 are a composite type. The circuits are pretty much the same except with the exception of the composite type uses a ground for each side headlamp, whereas the Sealed Beam shares a ground from one bulb.
I clean grounds even if they look ok. If theres any paint under a grounding location or corrosion, I make sure theres a solid ground since they are overlooked quite a bit.
Since the wires are all Black for the headlamp grounds, with the headlamps On, measure the voltage from the Black wire(s) to Battery Negative, do the same on the power side to Battery Positive. You should have a very low reading, towards 0volts.
You can do the same measurements from the engine block and body/frame to Battery Negative as well, checking for the same loss of voltage.
Its pretty simple setup, but do check the charging system, make sure it can handle the extra electrical load.
Jan 12, 2026 at 1:24 AM
BRUCEDUNCAN
  • 35 POSTS
I pulled the daytime running lamps fuse several weeks ago because I don't want the headlights on in the daytime. the high beam flickering occured with the drl fuse out. I will check alternator voltage and voltage at the bulbs in the meantime. The dashboard volt guage said 14 volts all the way home. When it's cold the volt guage goes up even higher. What is a composite bulb? My headlight is glass so I assume it's sealed beam.
With only one ground for both headlights would explain why both lights would flicker at the same time if it is the ground wire. A composite bulb wouldn't flicker both bulbs because there are two grounds one driver side one for passenger side. I will see if I can find the headlight ground. the diagram says the right side of the radiator support G109.
Jan 12, 2026 at 8:40 AM
BRUCEDUNCAN
  • 35 POSTS
Oh I plugged in the drl fuse I forgot to mention in my above reply. I don't know what i am doing but I hoped it would maybe get a better ground or help the situation. Bruce
Jan 12, 2026 at 8:43 AM
AL514
  • 5,692 POSTS
Correct. One setup shares a Ground and the other has a ground per side.
Does the flickering stop with the DRL fuse in? If it stops with the fuse in, I would leave it in. Daytime running lamps are standard on modern vehicles anyway and is not going to hurt anything.
If you want to continue testing and attempt to figure out whats causing it, see what dc voltage reading you get while the truck is running with the head lamps on High with the Red meter lead on one of the head lamp ground wires and the Black meter lead on Battery Negative. That will give you the voltage drop (or loss of voltage) on the ground side, between that head lamp connector and battery Negative. You dont want to have any voltage loss, but since you will have some, it should be a very low reading. Do this test on the power feed wire to the headlamp connector and B+ as well.
I understand this type of testing can be confusing sometimes because its the more advanced method than just reading the resistance of a wire. Resistance readings on long stretches of wire is almost pointless because the circuit is not loaded. Things change when there is a lot of current flowing. But do that test above, dont do multiple tests without knowing what the first tests results reveal. The flickering might be an issue with the route current is now taking because of that fuse being out though. Something to consider,
Jan 13, 2026 at 5:48 AM
AL514
  • 5,692 POSTS
How about leaving the fuse in and just pulling the DRL Relay? Id be curious just to see how the circuit reacts, it looks like that should still work, while still providing power to the control module. Thats something you'll just have to try.
I did see some troubleshooting section too, here for the Daytime running lights staying On. Im not sure the point of this test is though.
Jan 13, 2026 at 6:18 AM
BRUCEDUNCAN
  • 35 POSTS
Today is 1/13/26
I pulled the DRL fuse 2 weeks ago and had no issues with the lights until 2 weeks later. I put the fuse back in and today drove home with no flickering. What is a composite bulb?
Today I drove the truck for half an hour with my scanner reading voltage on Ign 1. Where is ign 1 located on the car to read voltage? The average voltage was 13.3 to 13.6 volts.
I had the High Beams on, the heater fan on high, the interior lights on, the windshield wipers on, the windshield washer motor on, the radio on, and I put it in gear and idled the truck for a few minutes the voltage never went below 13.1 volts. Bruce
Jan 13, 2026 at 10:00 AM
AL514
  • 5,692 POSTS
The sealed beam is the older style, where the entire headlamp was replaced. If you remember kind of back in day when it wasnt just a small bulb change (composite), it was that hole headlamp that plugged into the harness. You voltage readings sound really good actually. Ign.1 Im assuming thats is a data PID on your scan tool, its a measurement the ECM is taking on one of its battery power inputs. A computer this old is not going to be too sophisticated.
You could also check for any AC voltage at the Alternator post to Batt negative. I use a scope when checking but a meter will work. Set the meter on AC voltage, turn on a bunch of electrical loads again and you really want to see less than 100mv on, so set the meter on a low setting.
If the flickering issue is gone for now, and you really want the DRL off, see if the relay removed acts the same way.
Jan 13, 2026 at 11:11 AM
BRUCEDUNCAN
  • 35 POSTS
Today is 2/4/26
I fixed my headlights Al. Whoever bolted the battery tray in crushed a ground wire. I soldered in a new section of wire. I cleaned two ground terminals above and below the battery tray. The headlights don't flicker, they are brighter, the heater fan is faster, the turn signals are audible now and blink a little faster. With all electrical loads on in gear idling for 5 minutes I have 12.3 to 12.9 volts on my scan tool. Ign 1 wherever that reading comes from I don't know. I will check for ac voltage at the alternator post when it warms up. It's winter where I am. I am running with no DRL fuse. I don't want headlights in the daytime. I put on a gold plated battery bolt gold never corrodes or rusts.
I was wondering if you knew if my truck has a battery run down relay. My Monte Carlo had one. What state are you in?
Bruce Duncan
Feb 4, 2026 at 6:43 AM
AL514
  • 5,692 POSTS
Yeah, they look great, super bright. Grounds get neglected so much because people dont think about the return path for current. But Im glad you took the time to do the extra work with the battery and tray. It all ends up back at the battery. I am in NC. We just got slammed with over a foot of snow. The worst part is they just are not prepared here with trucks and salt. Im from up north, so I can drive fine in the snow, but this place shuts down when it snows an inch.
Im looking through the power distribution diagrams right now to check on any battery saver type relays or fuses.
Feb 4, 2026 at 7:00 AM
AL514
  • 5,692 POSTS
That loaded battery voltage being 12.9 is kind of borderline, but temperatures are just ridiculous right now.
There is a power module that is reserve power (36volts) for the airbag (SRS) system and power for diagnostics. Airbags are something you probably dont want to mess with. Setting off the airbags by accident can be extremely dangerous. Manufacturers usually have a flow chart for how to check certain sections of the SRS circuits.
What was your plan with the headlights now that they are working ok? Do the headlamps work ok with that fuse out?
Feb 4, 2026 at 7:18 AM
BRUCEDUNCAN
  • 35 POSTS
The headlights work fine with the fuse out. We got hit with a foot of snow as well. What does it mean if the alternator post has more than 100 mv ac voltage with the electrical loads on?
Feb 4, 2026 at 8:38 AM
AL514
  • 5,692 POSTS
Well since the Alternator puts out AC voltage it needs to be converted into DC voltage, so there is a diode trio. The diodes only allow the DC element through, when the diodes start to fail, and its usually just one at a time, there will be AC voltage spikes whenever that winding of the alternator comes around and it sends out the voltage. Its something we would use a scope to observe. But you can just do a search for "bad alternator diode waveform" and you'll see a picture of where there is a negative voltage spike.
The low voltage is a little concerning, that alternator was struggling awhile with bad grounds and a weak battery. Heres a guide on alternator testing. Where are you located ?
Feb 4, 2026 at 10:05 AM
BRUCEDUNCAN
  • 35 POSTS
I am in Marlborough, Massachusetts. Do you know where I can buy a used Dealer service manual for my truck? Bruce
Feb 4, 2026 at 10:30 AM
AL514
  • 5,692 POSTS
You can purchase access to service info for a number of days per vehicle if I remember correctly. All Data and Pro-demand I think both do that.
Feb 4, 2026 at 11:15 AM
BRUCEDUNCAN
  • 35 POSTS
Today is 03/04/26
Dear Al I had a little trouble getting a reading on the Alternator, the ground terminal on my battery is gold plated. I had to put a small battery charging clamp on it with no wire attached to it and I clipped my multimeter onto the charging clamp which worked good. the multimeter was struggling to get a reading without this charging clamp on.
I measured .096 volts AC at the Alternator Stud with loads on which is 96 millivolts.
I switched my meter to millivolts and read 000.1 millivolts. What part is bad if the reading is over 100 Millivolts? Rectifier bridge? Diode Trio? Bruce
Mar 4, 2026 at 9:05 AM
AL514
  • 5,692 POSTS
Hey there Bruce. I would be a bit concerned first with getting a good battery terminal connections, both on the positive and negative side. If youre having trouble getting a reading with a meter on a battery terminal, such as these sometimes painted terminals. Its going to be a little difficult to get a accurate reading if there is some connections that are not as solid as they could be. Theres some different specs when it comes to AC voltage ripple, 50-70ma is what Id like to see, but nothing is perfect and different vehicle makes have different max voltage readings.
But when a diode fails you will get AC voltage spikes and readings. Check your meter leads as well. Just connect them together, set the meter to Ohms and shake the leads, the resistance should stay a solid 0 Ohms. Meter leads that are starting to wear can really throw you down a rabbit hole, giving misleading readings.
When a diode fails, the alternator needs to be replaced or rebuilt, some places still do that.
Mar 5, 2026 at 2:14 AM
BRUCEDUNCAN
  • 35 POSTS
thanks, Bruce
Mar 8, 2026 at 11:09 AM
AL514
  • 5,692 POSTS
Yeah, of course no problem, hopefully it was helpful. Good to hear from you and I hope you get the rest sorted out ok.
Al
Mar 9, 2026 at 3:57 AM
BRUCEDUNCAN
  • 35 POSTS
Today is 11/11/26
Dear Al, it's Bruce again. My headlights were fine until yesterday. They are flickering again intermittently along with the blue high beam indicator on the dash. It doesn't matter if I am on a smooth road or a rough road it's intermittent.
The headlight plugs look good on both headlights no corrosion. The only thing I saw on the passenger side was a little bit of exposed wire where it goes into the connector but I saw no corrosion so I doused it in electrical grease.
You mentioned voltage drop testing from the headlight connector to the battery.
Wouldn't this only tell us anything when the headlights are flickering?
Do I back probe the headlight connector with my multimeter? It is almost impossible to do this on my truck. The passenger side connector is in front of the battery. I have to remove the battery and maybe the battery tray to get at it. If I remove the headlight the connector has next to no slack for me to pull it forward and back probe. I might be able to do it but what a pain. The driver side might be a tiny bit easier GM left basically next to no slack to the connectors.
Any chance it would be a weak or failing headlight switch self-resetting internal circuit breaker?
Nov 11, 2026 at 3:26 PM
