Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Engine
Flywheel
Bolt
Torque
Flex plate torque specs needed?
2016 FORD F-150
190,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
FABELNM
MEMBER
What's the torque spec for the flex plate to crankshaft bolts?
Mar 10, 2025 at 10:40 PM
Experienced Mechanic
Sure, this bolt is torqued to yield and are not re-usable. Flex plate torque specs.
Install the flexplace and the bolts.
Torque:
Stage 1: 20 Nm
Stage 2: 60°
Here is the tightening sequence. Check out the images (below). Let us know if you need anything else.
Image (Click to enlarge)
Mar 11, 2025 at 6:58 AM
FABELNM
MEMBER
Thank you very much.
Mar 11, 2025 at 11:27 AM
You are welcome, please use 2CarPros anytime we are here to help.
Mar 12, 2025 at 3:20 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
