Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
C1500
Engine
Flywheel
What are the torque specs for the studs on the flex plate?
1997 GMC C1500
300,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
CLL
MEMBER
I would like to know the torque specs for the studs on the flex plate please. Thanks.
Jul 6, 2024 at 12:17 AM
Experienced Mechanic
The torque specifications for the flex plate (also known as the flywheel) on a 1997 GMC C1500 with a 5.7L V8 engine are as follows:
Flex Plate to Crankshaft Bolts: 65 ft-lbs (88 Nm)
Let us know if you need anything else.
Jul 6, 2024 at 5:28 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
