Flat battery
1996 MERCEDES BENZ
100,000 MILES • 6.0L • V12 • 2WD • AUTOMATIC
DENIS ADAMS
How do I recharge battery when it is in the boot and that will not open open for access?
Jul 15, 2017 at 12:29 PM
HARRY P
  • 2,292 POSTS
Usually cars with a battery in the trunk ("boot") have terminal access points under the hood. The positive (+) should be covered with a red colored cap. If there is one for negative, it is covered with a black cap and probably has a (-) on it. If you can provide more specifics (model, sub-model, engine size, automatic or manual) I can probably look up more specific information. Let us know.
Jul 15, 2017 at 12:37 PM
DENIS ADAMS
There are no terminal access points under the hood unfortunately. Car is V12 coupe 1996.
Jul 15, 2017 at 12:41 PM
  • 55,766 POSTS
Okay, then you must connect power to the large lead of the alternator or starter to feed power into the battery which will allow you to get the trunk open
Cheers, Ken
Jul 17, 2017 at 5:39 AM
DENIS ADAMS
I opened up the fuse box & found a larger sized cable that had about 4volts left on it. Removed it's fuse & cut the cable to create a positive terminal block. Replaced fuse & connected a charged up battery to it & a negative to earth. NB: DO NOT start vehicle this way. There was enough power to open boot to get at the troublesome battery. Suspect collapsed cell, to be confirmed. Replaced battery started vehicle which can go in for a diagnostic checkup.
Jul 18, 2017 at 4:29 PM
HARRY P
  • 2,292 POSTS
Yeah I should've thought of that. Sorry. But at least now you know for the future. Nice work. Keep us posted
Jul 18, 2017 at 10:36 PM
