Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
200
Electrical
Lights
Warning
Flashing warning lights while driving
2012 CHRYSLER 200
177,000 MILES • 0.5L • 4 CYL • 2WD • AUTOMATIC
KKNIGHTEN83
MEMBER
1 POST
Flashing brake light, solid traction light, flashing ABS light, odometer goes back and forth from 0-60 all at the same time while driving.
Sep 11, 2021 at 6:50 PM
Experienced Mechanic
Good morning,
There is a fault in the ABS system. There is a code set that must be determined and then diagnostics were done to find the failure.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
You can have a parts store read the codes for you and once we know the codes, we can assist you further.
A common failure is a speed sensor but must be confirmed. I attached the location and procedure for the sensor replacement.
Images (Click to enlarge)
Sep 11, 2021 at 10:50 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Check engine light
Engine stalls while driving
