Flashing engine light and puttering
199,000 MILES • 5.2L • V8 • 2WD • AUTOMATIC
JFIO83
Recently my truck broke down kept making clunking sound when trying to start it. changed the distributor, ignition coil cam shaft, spark plugs and wires.
But any time i go over 70 mph engine light flashes and starts puttering.
Dec 19, 2018 at 5:49 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny,
Okay, first thing you need to do is access the check engine light code(s). If you don't have access to a code reader/scanner your local auto parts stores have a tool loaner program and can rent you one. Once you check the codes and get back to us with the code numbers we can help properly diagnose your vehicle. I've attached a tutorial showing you what is involved.
Hope this helps and get back to us soon. Thanks for using 2CarPros.
Danny-
Dec 19, 2018 at 6:02 PM
JFIO83
First initial time it said cylinder 1, 2 and 3 and did all that it said in previous message. but have not been able to check it this time.
Dec 19, 2018 at 6:05 PM
DANNY L
  • 5,648 POSTS
I did not answer you initial response. If you could provide me with all details that would be greatly appreciated.I would like all codes that you could provide to help you out.
Danny-
Dec 19, 2018 at 6:17 PM
