Do you have the actual code number? Chances are it is either a P0842 or P0843. The either codes deals with a pressure sensor. I will try to explain how it works. The transmission fluid pressure switch A (2nd clutch) is installed in the hydraulic pressure circuit to the 2nd clutch. When hydraulic pressure is supplied to the 2nd clutch, the switch is turned ON. When hydraulic pressure is not supplied to the 2nd clutch, the switch is turned OFF. The signal from transmission fluid pressure switch A (2nd clutch) is input to the powertrain control module (PCM). The PCM detects the hydraulic pressure supply conditions at the gear change to 2nd gear (1st --> 2nd, 3rd --> 2nd) to reduce the shock that occurs at the gear change. If transmission fluid pressure switch A (2nd clutch) is OFF while driving the vehicle with the rotation speed ratio of the input/output pulses is that of 2nd gear, the PCM detects a transmission fluid pressure switch A (second clutch) failure and stores a DTC.
Now, based on which of the two codes you got should help me determine if it is the sensor or if more diagnostics are required. Either way, and please understand this doesn't benefit me in any way, it isn't an easy job. There could be an electrical issues at the PCM, a bad sensor, an issue with the 2nd gear clutch pack, and so on.
I hope I'm not confusing you. And to be honest, I wouldn't think this is something that can be done by a lube tech. It requires a person with understanding, the right tooling, and the knowledge to narrow things down.
If you get me the code, I will send you the diagnostic flow chart so you can see what is involved.
Sep 30, 2019 at 12:32 PM
