Flashing check engine light
30,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
DONBIGGOOS
Had this problem failed to be fixed multiple times in the car listed above. Finally had ECM replaced and have driven 300 plus miles with no problem. Prior efforts included: ignition coils (3), total tune-up, replaced Mass Air Flow Sensor. Final report ECM showing not grounding properly to injectors #2 and #6.
Dec 18, 2018 at 7:19 AM
Good evening,
Do you have a continuing issue?
If so, what is the current issue?
Dec 18, 2018 at 10:36 AM
DONBIGGOOS
No, thankfully seems it is fixed. I have driven it over two weeks and 350 miles. However, the last time I got it from Ford dealership, it was fine for about 400 miles and without warning, the check engine light began flashing again. Hopefully the new ECM took care of the situation.
Dec 18, 2018 at 7:30 PM
Okay, let us know if you need further assistance.
Dec 18, 2018 at 7:45 PM
DONBIGGOOS
Dec 18, 2018 at 8:38 PM
You are welcome.
We are always glad to help.
Dec 18, 2018 at 8:39 PM
