Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Saturn
L200
Exterior Light
Turn Signal
Flasher
Location
Flashers location
2002 SATURN L200
104,000 MILES • 4 CYL • AUTOMATIC
LIL OZ
MEMBER
The signals and hazards don’t work. Need help locating where the flashers are on the car, don’t have the manual.
Jan 8, 2019 at 11:21 PM
Experienced Mechanic
Good morning,
The hazard flasher is the switch for turning on and off the hazards. did you replace this? very common failure.
Picture and procedure attached for you to view. you can get the flasher at any parts store.
1. Remove the instrument panel (I/P) trim panel.
2. Release the tabs and push on the switch from the back side of the panel.
3. Remove the switch (1).
Image (Click to enlarge)
Jan 8, 2019 at 11:58 PM
LIL OZ
MEMBER
Yes I did that.
Jan 9, 2019 at 8:14 PM
You did what? did you replace the flasher assembly?
please explain?
Did you verify power at the fuse box on both the turn signal fuse and the hazard fuse? use a test light to check for power with the key on
Jan 9, 2019 at 9:12 PM
LIL OZ
MEMBER
I replaced the switch and checked the fuses.
Jan 10, 2019 at 2:15 AM
Got it but the flasher is what controls both the turn signals and the hazards as well.
Did you replace that flasher?
Jan 10, 2019 at 2:27 AM
LIL OZ
MEMBER
No I need to locate the flasher.
Jan 10, 2019 at 2:53 AM
I attached a picture on my first post. It is the 4 way hazard switch.
Jan 10, 2019 at 2:57 AM
LIL OZ
MEMBER
Okay checking.
Jan 10, 2019 at 3:01 AM
Sounds like a plan.
Jan 10, 2019 at 3:03 AM
LIL OZ
MEMBER
Okay, I found it, but I’m having a tough time removing it. Is there a tool needed?
Jan 10, 2019 at 3:25 AM
No tool. You need to release the clips that hold in the dash. you could use a small screw driver to move or release the clips.
Jan 10, 2019 at 3:27 AM
LIL OZ
MEMBER
Thank you so much I fixed it!
Jan 10, 2019 at 10:29 PM
Good job.
Glad you got it fixed.
You are welcome.
Always glad to help.
Jan 10, 2019 at 10:31 PM
Add image or video
Ask a new question
Engine won't start
Engine has low power
