Flashers not working properly
134,000 MILES • V8 • 4WD • AUTOMATIC
LACAJUN
installed LED flashers in rear, no problem. Installed LED flashers in front and right flasher settled in, left flasher had a problem. With lights "off" left flasher will flash but so does the display lighting and the radio lighting. With lights in the "on" position left arrow appears on display, does not flash. I have changed the flasher relay, GM11516051with newer relay designed to work with LED's. Did not fix the problem.
Nov 19, 2016 at 8:56 AM
  • 55,682 POSTS
Hey LACajun,
One of two things is happening, either you got the wires mixed up or the resistance in the LED kit will not work with the BCM of the vehicle.
I would recheck the wires and then if that does work put back the stock lights to see if that works.
Please let us know happens so it will help others.
Best, Ken
Nov 22, 2016 at 12:09 PM
LESTAHOE
where is the turn signal flasher located?
May 17, 2020 at 4:02 AM (Merged)
  • 75,988 POSTS
Turn/Hazard Flasher-see location below: Convenience Center
https://images.2carpros.com/forum/automotive_pictures/12900_t_32.jpg
