Flasher relay replacement
210,000 MILES • 2.2L • 4 CYL • 2WD
SNDMAN1964
I have located the flasher relay, but it is held in place by a plastic nub that is protruding through a metal bar. How to I remove it?
Mar 3, 2018 at 3:39 AM
  • 55,849 POSTS
The flasher relay is located at the lower left of the dash near the steering column. Here is a wiring diagram and a guide to help you see if it is getting power to confirm the issue.
Check out the diagrams (Below)
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Mar 5, 2018 at 3:45 AM
