after fixing fuel pump and replaced camshaft sensor it will not start
120,000 MILES • 2.5L • 4 CYL • 2WD • MANUAL
CHELSA-ELIZABETH RADUS
Car started after initial replacement of pump and camshaft sensor we drove the car parked it, had to remove pump to check floater gauge. We tried to start car again and it would not turn over, and realized we were leaking gas from front of car near engine/dashboard. It only leaks when we are trying to turn over vehicle! Any information would help.
Oct 16, 2017 at 3:00 PM
  • 31,937 POSTS
During crank start the starter is on for a few seconds to build up fuel pressure, you will have to trace the fuel lines to see where it is leaking. cycling the key will pull the pump in when the pressure drops, you should not have a problem locating this leak. post back with your findings for further assistance.
Oct 16, 2017 at 5:00 PM
