Fixed crank seal and cam position sensor and now no start
232,019 MILES • 3.8L • V6 • RWD • AUTOMATIC
OG JESSE JAMES
I recently just had my cam position sensor replaced as well as my crank seal behind the harmonic balancer now the car will not start it all. it is supercharged. before the repair it was leaking out the harmonic balancer slinging oil all over my belt assembly making it hard for me to diagnosis, now I seem to not be having spark. What could it be? any ideas will help. Thanks
Aug 20, 2017 at 8:31 PM
  • 55,583 POSTS
It sounds like you lost your crankshaft position sensor. The engine will run without a cam sensor but not a crankshaft sensor. Here is a guide hat will show you what you are in for when replacing the sensor:
Here is what it will be like on your car.
Cheers, Ken
Aug 21, 2017 at 10:59 AM
OG JESSE JAMES
After installing a icm, spark plugs an wires and a fuel pump the car is running well until it gets cooler outside then it's harder to start any ideas on why
Aug 30, 2017 at 9:56 PM
  • 55,583 POSTS
It sounds like you could have a coolant temperature sensor that is off a little or you may have a vacuum leak, here are two guides to help you get the problem fixed.
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
and
Please let us know what you find.
Cheers, Ken
Aug 31, 2017 at 2:41 AM
