code P0172?
2000 TOYOTA TACOMA
231,000 MILES • 2.7L • 4 CYL • 2WD • AUTOMATIC
FAYE MCGOVERN
Just picked up my truck from dealership.they didn't know how to fix it.it is throwing code PO172. They replaced fuel injectors, spark plugs, catalytic converter, 2 sensors, fan clutch, injector sub assembly, 1 air flo ratio sensor,body sensor, direct fit cat coupling assembly, it's still throwing a code. Runs okay when truck heats but misses a little when first starts up in the morning. I'm at a loss. what should i do next?
Jun 21, 2021 at 8:54 PM
  • 110,244 POSTS
By any chance, do you have access to a live data scanner? The code indicates bank 1 is running rich. It's a 4 cylinder so there is no bank 2. A rich mixture simply means there is too much fuel entering the combustion chamber and not enough air. The air/fuel ratio is off.
I need to know a couple of things. If you have a live data scanner, let me know what the short-term fuel trims are. Also, if you feel a misfire, there should be other codes. Is this the only one? Have you ever noticed black or gray smoke from the exhaust? Any odd smells?
The idea that they did the things you indicated leads me to believe that either you have a faulty fuel pressure regulator or there is a wiring issue between the o2 sensor and the ECM. Heck, it could be something as simple as a restriction in the air induction (air filter box and hose that goes to the throttle body).
Let me know if they replaced anything other than the injectors with the fuel system. Also, please confirm this is a 2.4L. You indicated a 4 cyl but typed 2.7L.
I'm including a couple of things I would like for you to check. See below.
If they haven't done anything with fuel pressure, here is a link that explains in general how it's done. You will need a fuel pressure gauge, but most parts stores will lend you one.
I attached a pic below showing possible causes for the code.
Pic 2 below shows the fuel pressure regulator. I highlighted a vacuum hose that runs to it. Remove that hose and check for evidence of gas in the vacuum hose. Also, have a helper start the engine and confirm there is vacuum to the hose.
Pic 3 is the manufacturer's specifications for fuel pressure.
Let me know as much as you can and what you find.
See pic below.
Jun 22, 2021 at 2:38 PM
MONTASSER
Hi Joe
I have Tacoma 2008 2.7L M/T 2WD 2TR FE engine With code P0172 I Did everything I mean everything I still have the code and the truck running rich I don't know what to do Maybe you have any advice ! Thanks Mo
Sep 25, 2025 at 9:59 AM
  • 55,423 POSTS
Did you check the vacuum line from the fuel pressure regulator? If fuel is present this is your problem. Also, please go over this guide as well.
https://www.2carpros.com/articles/why-an-automotive-engine-will-run-rich
Please upload pictures or videos in your response
Sep 27, 2025 at 3:42 AM
