Fitech code P0201
150,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
CINDYJACOBS
Code reads as a injector circuit malfunction cylinder1. How do I repair this problem?
Aug 4, 2018 at 7:35 AM
Good afternoon.
Is this a 1965 Ford Fairlane? If it is, was there a conversion done to this?
Can you clarify?
Aug 4, 2018 at 8:17 AM
CINDYJACOBS
It is a 1965 Fairlane with a 1970 motor, 302. 5.0.
Aug 4, 2018 at 8:31 AM
1970 is too early for fuel injection and a code. Try again.
Aug 4, 2018 at 8:38 AM
CINDYJACOBS
It has a Fitech EFI 3003.
Aug 4, 2018 at 8:45 AM
STEVE W.
  • 15,409 POSTS
You would need to talk to Fitech as this is not anything that would be covered in normal service information. The code itself means there is an issue with the fuel injection. Could be an injector or wiring issue. However as this is a custom four injector unit that is not really service friendly the company would be the first place I would talk to.
Aug 4, 2018 at 8:55 AM
