first gear does not work in drive
100,200 MILES • 4.0L • V6 • 4WD • AUTOMATIC
EDC101486
When sitting still if you put the truck in drive and let off the brake the truck does not move even if you push on the gas. To get it to go I have to put the transmission into second gear only spot then when I get to 15 mph shift into drive and the rest of the gears work. I believe someone did work on the transmission before I owned it cause the shift lever wont go far enough to get the first gear only spot. I have put it up on jack stands put it in second gear only spot then went underneath and pushed on the shift linkage to get first and it worked the tires started spinning. The person who owned it before me said he got it stuck in a creek and that's when the problem started
Jul 3, 2014 at 2:24 AM
HMAC300
  • 48,601 POSTS
have a trans guy look at it sounds like a valve body problem and when the guy got it stuck in the creek, he could have also damaged or burnt the seals and clutch or broke a roller clutch as well as the cable has probably stretched so needs either anew one or adjustment
Jul 3, 2014 at 5:02 AM
