Firing order/coil order
150,000 MILES • 3.7L • 6 CYL • 2WD • AUTOMATIC
JOSE GARCIA2
  • 8 POSTS
Looking for the coil order/diagram for this truck. took the motor apart now I need this order. Please and thank you!
Feb 12, 2020 at 3:51 AM
Good afternoon,
I attached the firing order and the cylinder location for you. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Feb 12, 2020 at 4:36 AM
DXHHH6
V8 four wheel drive manual 74,000 miles.
Does anybody know the firing order for my truck listed above it is a 1500 pickup, or know where i can find a diagram? I have tried a couple of different ways which people have told me how to do.
Sep 11, 2020 at 6:47 AM (Merged)
  • 75,988 POSTS
There you go and have a nice day.
https://images.2carpros.com/forum/automotive_pictures/12900_fo_50.jpg
PAUL4277
I am unable to find the firing order for my Dodge Ram 1500 V8. I know the wires were routed wrong, but don't have the correct order. Also, please verify the orientation of the order when looking from the front.
Thanks!
MOPARTECH9423
  • 25 POSTS
The firing order for the 5.2L and 5.9L is stampped on the intake maninfold. Its on the top of the manifold. The distributor rotation is also stampped on the intake just in front of the distributor cap.
Sep 11, 2020 at 6:48 AM (Merged)
PAUL4277
Thanks a ton! Funny... when they are correct, it runs like a champ.
The mechanic (and I use that term generously in his case) swore he'd done nothing wrong, but "would be glad to fix it for a price."
JOE_MACKAY
I Cant figure out which plug wires go to whitch plug. The new wires i got aren't the same size as the stock ones and the stock ones have different numbers on them than the new ones. What plug wire goes to what Plug. I have 8mm wires. my truck is a 99 dodge Ram 2500 488 V10
  • 75,988 POSTS
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. The 8 cylinder diagrams is in the next post down.
https://images.2carpros.com/forum/automotive_pictures/12900_sp_4.jpg
MCOLLETTE1
I've read the code on my 318, showing a misfire on #4 cylinder. Trying to figure out how they are numbered, and will plugs and/or wires fix the problem.
  • 75,988 POSTS
Check the no. 4 sparkplug/compression/injector Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel
https://images.2carpros.com/forum/automotive_pictures/12900_fo_53.jpg
MPEEBLES
I would like to know what the firing order for this engine. I replaced spark plugs, distributor and rotor and the engine is missing now.
HBAUGH
  • 8 POSTS
The firing order for you car is - 18436572
Please let us know if you need anything else to get the problem fixed. Cheers,
TER29
Engine Mechanical problem
1997 Dodge Ram Two Wheel Drive Automatic 100,00 miles
360CI
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Ram_Van_1500_V6_1.jpg
V8 5.2L & 5.9L
https://images.2carpros.com/forum/automotive_pictures/99387_Ram_V8___52_L_1.jpg
WARREN JACKSON
firing order for a 318 dodge engine?
DOCFIXIT
  • 18,828 POSTS
Here is the engine spark plug firing order. Check out the diagrams (Below).
Cheers
BARBARA1963
  • 99 POSTS
can you send me a diagram of the plugs positions on top of the distributor cap?
Sep 11, 2020 at 6:49 AM (Merged)
CJ MEDEVAC
  • 11,000 POSTS
Miss Barb,
I have the "textbook diagram" of the firing order, click on the diagram below.
If the distributor has been removed now/ or in the past and the rotor button position was not placed exactly where it originated, then this diagram may deceive you!
Depending on the situation with the distributor's history (recent or past)
The actual order or sequence is set "In Stone",
the possible "head scratcher" is where #1 wire starts the sequence on the distributor cap. The Distributor "does not care" where the sequence starts (on the cap's towers) as long as #1 is in sync with TDC (Top Dead Center) of the engine.
With all that being said, hopefully your stuff is still easy and "textbook"
If by chance the distributor was taken out and not reinstalled 100% the way it came out/ Or the engine was turned while it was out, return with the "rest of the story", maybe I can help you find TDC and how to install the distributor so you will know where to start the sequence.
Return with good news!
The Medic
PAASTORMICHAEL_365
Electrical problem
1987 Dodge Ram V8 Two Wheel Drive Automatic
What is the spark plug firing order for 1987 Dodge van-5.9L? Where is no. 1 on cap?
  • 75,988 POSTS
Here you go
https://images.2carpros.com/forum/automotive_pictures/12900_dodge_fo_2.jpg
CARMENJONES
Hi, Went to autozone who told me the #6 spark plug wire may be faulty off the test light. Do you have the location of each of the spark plug? Thanks!
Dec 19, 2020 at 1:57 AM (Merged)
MERLIN2021
  • 17,250 POSTS
This is 5.2 V8 5.9 is the same. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
https://images.2carpros.com/forum/automotive_pictures/62217_52_firing_Order_1.jpg
