Firing order and wire routing diagram needed
209,008 MILES • 5.9L • V8 • 2WD • AUTOMATIC
DUSTIN HENGST
I need a diagram of the plug firing order and a diagram of the wire routing for my vehicle listed above. please
Mar 26, 2022 at 11:05 AM
  • 110,248 POSTS
I attached a picture below of the distributor and the engine cylinders. Simply run the spark plug wires from the distributor cap to the plugs following the numbers indicated.
The firing order is 1 8 4 3 6 5 7 2
Let me know if this is what you need.
See pic below.
Mar 26, 2022 at 12:26 PM
