Firing order?
100,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
JERS420
I'm looking for the firing order for my car listed above ltz.
Sep 15, 2019 at 4:05 AM
Good afternoon,
I attached the firing order for you. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Sep 15, 2019 at 5:30 AM
JOEY69
Need to know the firing order.
Sep 19, 2020 at 6:40 AM (Merged)
HARRY P
  • 2,292 POSTS
Here it is.
WRENCHTECH
  • 20,760 POSTS
I believe this is what you are probably looking for.
BLAKE1985
what is the firing order for a 6 cylinder 3.1 engine
2CARPRO JACK
  • 11,533 POSTS
here ya go
https://images.2carpros.com/forum/automotive_pictures/1639_31_1.jpg
MICROPHONE DOCTOR
Six cylinder automatic 120,000 mile.s
What is the firing order for the spark plugs? when changing the spark plugs I think the firing order got mixed up.
BLUELIGHTNIN6
  • 16,542 POSTS
Firing order for the 3.1 liter is below. 3.1 liter engine: Firing order: 1-2-3-4-5-6. Distributor-less ignition system.
https://images.2carpros.com/forum/automotive_pictures/261618_0900c1528024baf7_1.jpg
Thanks for using 2CarPros.com!
ALDEAN49
Engine Performance problem
2000 Chevy Malibu 4 cyl Front Wheel Drive Automatic
What is the firing order for a 2000 Malibu 3.1?
LSAUTO
  • 61 POSTS
the firing order is Firing order: 1-2-3-4-5-6. and the coils should have the cyl marked hope this helps lsauto
SODAJOE
1999 Chevy Malibu
what is the firing order and cyclinder placement for a 3.1 v6
RHALL77
  • 3,361 POSTS
https://images.2carpros.com/forum/automotive_pictures/166241_15977_1.jpg
cylinders 2, 4, 6 are at the front of the car 2 being at the front of the engine. 1, 3,5 are at the firewall side of the engine and 1 is starting at the front of the engine
RND
I need a diagram for firing order for coil pack and spark plugs
  • 55,694 POSTS
Here is the cylinder order as well (below) Please let us know if you need anything else to get the problem fixed.
Firing Order .................... 1-2-3-4-5-6
JUSTIN_19
i need a diagram on a v6 3.1 engine on a 1997 chevy malibu LS. Its that i dont know the sequence and i know im supposed to mark them but i thought i knew where they went but i sort forgot where they went so if i can know the order of it or show me a diagram
RHALL77
  • 3,361 POSTS
1,3, 5 are on the firewall side of the engine. #1 ia up front. 2,4,and 6 are on the radiator side. #2 is at the front of the engine. your module should be labeled all ready.
KENDRICK DENSON
1997 Chevy Malibu 6 cyl Two Wheel Drive Automatic
Put in new spark plugs and new wires but dont remember what order the wires go
Sep 28, 2020 at 3:27 AM (Merged)
SERVICE WRITER
  • 9,123 POSTS
https://images.2carpros.com/forum/automotive_pictures/30961_Wcf_1.jpg
