Please let me know little bit more about what you are experiencing and what you have done so far.
Image (Click to enlarge)
Oct 9, 2021 at 8:50 AM
DON KLINE
MEMBER
I changed them to the other side, and they worked fine. Unplugged the ones on the passenger side and it didn't change the way the car runs. It doesn't have any fire to them at all.
Oct 9, 2021 at 10:02 AM
DON KLINE
MEMBER
It's like it has no electric power going to the coils.
Oct 9, 2021 at 10:17 AM
SQM
✓Experienced Mechanic
Check the coil connectors (harness). Do you have power there?
Take a look at the wiring schematics below, it is for the coils. As you can see, they have separate ground for each bank.
If you have no power to the coil connectors, then it could a short in that harness.
Oct 9, 2021 at 11:36 AM
DON KLINE
MEMBER
Could i still have power to the driver's side? Because I have power to the driver's side just not the passenger side.
Oct 9, 2021 at 11:54 AM
SQM
That right. As you can see, they have separate ground for each bank. The issue could be after the junction.
