location of crankshaft position sensor
124,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
DIANALENDZ
finding location of crankshaft position sensor on 2009 chevy aveo where is it located?
Do you have a diagram of the location of the crank shaft position sensor. I still can't find it.
There emission tube and below it nothing, engine part bolts only.
Does the engine cover have to be removed to see it
When I look at that spot there is nothing there. No wires, nothing else.
I have an ECOTECH engine
Coming up with P0340 & P0365 codes. Crankshaft position sensor?
Aug 5, 2014 at 11:22 AM
  • 55,562 POSTS
Hey DIANALENDZ,
There are two different locations depending on if you have variable timing or not here is a guide to show you what you are in for when changing the sensor and the location of the sensor BELOW
Cheers, Ken
Jan 5, 2017 at 2:12 AM
  • 55,562 POSTS
Hey,
Did you ever get the problem fixed?
It sounds like you may have a timing chain that is having a problem?
Best, Ken
