I poured one bottle of dry gas into the tank. Yes the fuel pump sounds strong. Just replaced the distributor plugs and wires also. yes it smelled like fuel.
Nov 19, 2019 at 6:29 PM
✓Experienced Mechanic
The dry gas will have little or no effect.
You would need to drain the entire tank and add fresh fuel.
That is if the fuel is the issue.
Nov 19, 2019 at 6:39 PM
PARKS PAUL
MEMBER
How is that to be done? Is there any other solutions?
Nov 20, 2019 at 9:26 AM
You would need a siphon to remove the bad fuel from the tank. Then you can add the new fuel.
No, there is no other solution.
This is assuming that the fuel is the issue.
Nov 20, 2019 at 9:30 AM
PARKS PAUL
MEMBER
The quickest way to siphion all of the fuel from a tank that has been topped off would be a hose going into the fuller neck?
Nov 20, 2019 at 9:42 AM
Correct.
Nov 20, 2019 at 9:58 AM
PARKS PAUL
MEMBER
Would it be faster to disconnect the fuel filter and keep on priming the pump?
Nov 20, 2019 at 10:19 AM
It only runs for 2 seconds at a time. it would take a long time.
