2001 Fiat Ulysse wont run
2001 FIAT ULYSSE
JEFF DAVIES
Electrical problem
2001 Fiat Ulysse 4 cyl Two Wheel Drive Manual
hi the problem is i have fitted a new fuel pump a new relay the car will start and run for about 10 seconds seems like the pump stops if i turn the keys off then it will start agin and run for about 10 seconds agin any help thanks jeff
Feb 17, 2009 at 5:53 AM
DAVE H
  • 13,384 POSTS
sounds like you may have a fault on the immobolizer ?
Mar 21, 2009 at 3:25 AM
