2004 Fiat Stilo set the idling speed
2004 FIAT STILO
HEARTBROKENX
Engine Mechanical problem
2004 Fiat Stilo 4 cyl Front Wheel Drive Manual
we are trying to find the screw to set the the revs as the car was sounding bubbly so i changed the spark plugs but still sounding the same and also the revs are a bit low and sound bubbly :(
please help
thank you
Dec 5, 2008 at 11:32 PM
DAVE H
  • 13,384 POSTS
The PCM (computer) controls adle speed .. it is non adjustable .. you will need to check the IAC (idle air control) valve
Jan 20, 2009 at 9:22 PM
