2004 Fiat Stilo ignition coil
62,000 MILES • 4 CYL • 2WD • MANUAL
GARRY THOMPSON
car is misfiring i changed plugs how do i test or check ignition coils or could it be something else
Thanks
Aug 20, 2010 at 12:10 AM
DAVE H
  • 13,383 POSTS
find out which cylider is misfiring .. swap 2 of the plug leads one from misfiring cylinder to a cylinder which is not misfiring .. if misfire swap to new cylinder location you have a bad wire/plug .. if it stays on same cylinder you have a bad coil or it could be an injector
Sep 30, 2010 at 1:02 PM
