2003 Fiat Stilo Rear shock noise
75,000 MILES • 4 CYL • 2WD • MANUAL
MARKPOCOCK
I have recently had my rear gas shocks (and bushes) replaced as I was receiving a large thud as I went over bumps or dips in the road. This is happening on boths sides, offside and near.
Since replacing the shocks, the noise is still there and is getting increasingly worse to the point where I dont like driving the car.
How likely is it to be the axle bushes ? If not, what else could it be ?
Kind regards
May 1, 2008 at 12:30 AM
DAVE H
  • 13,383 POSTS
seems strange that both sides should go at the same time ? ask your mechanic to have a look around underneath with a pry bar to find the exact problem .. he shouldn't charge you just for locating the problem ?
Nov 8, 2008 at 9:55 PM
