1980 Fiat Spider Starting
CHUCK CARNEY
Electrical problem
1980 Fiat Spider 4 cyl Two Wheel Drive Automatic
Had trouble with the starter. Removed it had it tested. Tested good. Reinstalled to engine. Now I have power to the starter from the battery, but no where else. No lights, radio, nothing. Starter will not do anything when key is turned. Where would I look for the open?
Mar 17, 2009 at 4:36 AM
DAVE H
  • 13,383 POSTS
check fuses .. check ignition switch and wiring
Feb 25, 2010 at 9:45 PM
