2000 Fiat Seicento Battery??
EWOM75
Engine Performance problem
2000 Fiat Seicento Two Wheel Drive Manual 78830 miles
I bought a car today, it started first time. I test drove it round the block for a test drive and it seemed fine. After driving it home (an hour and a half) i stopped to get a gate pass and then the car wouldn't start. A couple of lads bump started it and the car got me home. When i got home I stopped the car and then tried to re-start it but it didn't work. I went out an hour later and tried again and it worked!! What is wrong with the car??
Apr 16, 2010 at 6:46 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I would start with getting the battery load tested, check the alternator charge rate, then get the starter tested if you still have a problem, start here.
Mark (mhpautos)
Apr 18, 2010 at 11:58 AM
