2008 Fiat Scudo gear box/clutch
2008 FIAT SCUDO
98,000 MILES • 4 CYL • 2WD • MANUAL
JOCKBAIRD
has anyone had a problem with the dual master clutches on a fiat scudo 2008 model please let me know
May 14, 2010 at 1:37 AM
  • 31,937 POSTS
Hi there,
can you describe what your actual fault is/
mark (mhpautos)
May 14, 2010 at 1:41 AM
JOCKBAIRD
3 times the clutch has been repaired and 3 times it has gone it was replace in march this year and has done just over 6800 miles and is away again they saying its driver error !!
May 14, 2010 at 1:50 AM
  • 31,937 POSTS
If the clutch is burning out, it must be slipping, this can only happen if there is pressure on the thrust bearing, now is this a hydraulic or cable clutch? is the clutch genuine or after market, do you drive a lot of stop start driving such as heavy slow traffic?
mark (mhpautos)
May 14, 2010 at 2:10 AM
