2000 Fiat Punto Fan Heater not blowing
2000 FIAT PUNTO
80,000 MILES • 4 CYL • FWD • MANUAL
KAREN CASE
Heater fan starts but no hot air comes out of the vents
Dec 13, 2009 at 10:49 AM
Check and test the thermostat and check if the heater core is clogged-up if both okay -problem could be coming from an air mix/blend/mode doors, vacuum and actuator and HVAC contorl module
Dec 13, 2009 at 11:37 AM
