heater not working
34,145 MILES • 4 CYL • FWD • MANUAL
IAN.BRIDGE
heater not working blows cold air,sometimes hot for a few mins.water level are ok.The pipes are hot to and from heater rad.
Oct 16, 2008 at 10:52 PM
DAVE H
  • 13,383 POSTS
It sound like you have an air bubble caught the heater core. Here is a guide to help fix the problem.
https://www.2carpros.com/articles/car-heater-not-working
Feb 22, 2009 at 3:31 PM
TMAJKA
THanks for this post I had this problem and had to change the blend door actuator for the temperature mode.
Jan 12, 2019 at 9:37 AM
2CP-ARCHIVES
  • 4,540 POSTS
Heater blowing cold?
Jan 12, 2019 at 9:37 AM (Merged)
  • 110,251 POSTS
Make sure the coolant is full. Check to make sure both heate core hoses are getting hot, If they are, check the blend air door operatio. If they are both hot, check the blend air door. If only one side is hot, back flush the heater core.
