THanks for this post I had this problem and had to change the blend door actuator for the temperature mode.
Jan 12, 2019 at 9:37 AM
2CP-ARCHIVES
MEMBER
Heater blowing cold?
(Merged)
✓Experienced Mechanic
Make sure the coolant is full. Check to make sure both heate core hoses are getting hot, If they are, check the blend air door operatio. If they are both hot, check the blend air door. If only one side is hot, back flush the heater core.
(Merged)
