2003 Fiat Palio Temperature Indicator Rising when A/C on
2003 FIAT PALIO
48,000 MILES • 4 CYL • 2WD • MANUAL
TOMEXPLORE
HI All,
When i switch on the A/C the temperature level goes to the RedMark level after driving for 3 kms. I have checked the Fan its working proper. Refilled the A/C gas. When the A/c is off there is no problem with the temperature ridsing
Any help to diagnose the problem please
Thanks in Advance
thomson
Mar 15, 2010 at 4:36 AM
DAVE H
  • 13,384 POSTS
check the coolant level is correct .. replace thermostat and flush cooling system
Mar 17, 2010 at 2:50 AM
TOMEXPLORE
Did both, Did not help
Mar 17, 2010 at 4:10 AM
