2003 Fiat Palio
2003 FIAT PALIO
56,000 MILES • 4 CYL • 2WD • MANUAL
RANA
two interrelated problems
1. if staring sequence is followed, the "injection system abnormal " indication LED is on , the engine starts but RPM very unstable and also the acceleration.
2. To avoid the above, the ignition key is turned at one go (probably bypasses the safety system), the engine starts normal.
But very recently, once the throttle is very lightly pressed after accelerating, sometimes feels like the engine stalls sometimes causing jerks.
kindly revert with your views
brgds, Rana
Apr 2, 2010 at 8:48 PM
DAVE H
  • 13,384 POSTS
have the vehicle plugged into a diagnostic computer to locate the cause of the fault
Apr 9, 2010 at 9:00 PM
RANA
[quote:beed62ca20="Dave H"]have the vehicle plugged into a diagnostic computer to locate the cause of the fault[/quote:beed62ca20]
have done, indicating two problems,
1. p/p rotor position sensor fault
2. glow plug abnormal
tectnician suggested to o-haul the fuel p/p which may cost upto Rs35000, that too without any guarantee for this job - that discouraging me to spend such hefty amount on this 7 yr old car.
awaitaing your valued suggestion.
Apr 10, 2010 at 3:20 PM
