Kind regards,
Paul
Inspect the rear suspension and axle bushes for play or deterioration, as worn bushes commonly cause a rear thud and vibration over bumps after shocks have already been replaced. Confirm the source by bouncing the car and checking stabilizer or drop links for movement. Replacing the rear bushes may require removing the rear subframe and springs, disconnecting brake hoses, and bleeding the brakes afterward. Front drop-link bushes can fail similarly and are worth checking at the same time.
The owner of a 2003 Fiat Stilo Multiwagon 1.9 reported a loud thud and vibration from the offside rear over bumps or potholes. Rear shock absorbers had already been replaced without improvement. An expert suggested recreating the noise by bouncing the car and checking rear stabilizer links for movement. Another owner who had the same symptom said replacing the rear suspension bushes cured it, noted that the job can require dropping the rear subframe and bleeding the brakes, and also recommended checking the front drop links. A further owner reported the same noise after new rear shocks and suspected the rear axle bushes.
