2001 Other Fiat Models LOOSING POWER INTERMITENTLY
2001 FIAT
98,000 MILES • 6 CYL • FWD • MANUAL
SDONLEY
Hi wonder if you can help when driving my fiat brava it seems to loose power intermitently until i change down gear and it revs it then comes back for a short while then dies again one i hit uphill roads would you know what could be wrong with it?
Nov 20, 2009 at 10:58 AM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated From your brief description of the fault .. it may be the clutch is starting to slip under load when hot .. have the clutch checked !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_236.png
Nov 21, 2009 at 11:44 AM
