1999 Other Fiat Models engine misfire
1999 FIAT
82,000 MILES • 4 CYL • FWD • MANUAL
MSBACTIVES
hi there, just replaced head gasket on my fiat punto,
pior to that the engine was miss fireing, however after warm up say 2 miles ok. replaced plug leads, now when i start up ok run upto 3 miles when temp reachednormal engine starts miss fire on one or more plugs. sounds like to much fuel ?. is there a fuel sensor do i need to replace the sensor or ecu and if so where do i locate it, and the engine does not overheat please can you help as i am stuck, manythanks regards margaret
May 19, 2008 at 6:12 PM
DAVE H
  • 13,384 POSTS
check for correct fuel pressure
Nov 7, 2009 at 9:20 PM
