1994 Other Fiat Models
1994 FIAT
100,000 MILES • 4 CYL • FWD • MANUAL
DEANO_182003
Hi i hope u can help my punto mk1 55sx is pulling to the left side i have recently put new subframe gearbox mount bottom arm and shocker on the left side and it still pulled, so i took it to a garage to have it tracked up and they noticed a fault and charged me nothing i have a printout of the tracking which shows something isnt right (also has camber n caster angles on if needed) if u straighten up the wheels and look from a distance at the front u can see the right wheel is straight but the left is turned to the left i would be realy pleased if u could help me out with this problem thanks in advance
May 29, 2008 at 2:47 AM
DAVE H
  • 13,384 POSTS
check steering and suspension for damage
Nov 7, 2009 at 9:22 PM
