1998 Fiat Marea WILL NOT START
89,800 MILES • 4 CYL • 2WD • AUTOMATIC
KCHAMBERS
RANOUT OF PETROL , PUT 2GALLERS IN NOW IT WILL NOT START CHARGED BATTIER 3-4 TIMES AND HOOKED IT UP TO JUMP LEADS WOULD NOT START ,IT WAS TRYING BUT SOUNDED LIKE IT WASNT FIRERING
Apr 27, 2009 at 5:52 AM
TURBODIESEL1993
THIS IS A PROBLEM THAT OCCURS TO ME VERY OFTEN. I FORGET TO PUT FUEL IN TANK AND THEN I HAVE PROBLEMS TO START IT. WHAT YOU SHOULD DO IS WHILE TURNING THE KEY U PRESS THE GAS PEDAL AND LEAVE IT AND STAY DOING IT FOR A WHILE TO HELP THE FUEL SYSTEM GET PETROL FROM THE TANK. hOPE THIS INFO HELPS YOU. GOOD LUCK!
Sep 20, 2009 at 8:26 AM
