1988 Fiat Ducato Running on Vegetable oil
100,000 MILES • 4 CYL • 2WD • MANUAL
REINO
I own a 1988 FIAT Ducato with 2.5 L Turbo Diesel engine type Sofim 8144.21. I converted it with SmartVeg to run on vegetable oil. However, as a result the timing belt has broken once, and after rebuilding the engine the timing of the Diesel pump slipped twice out of timing. I already heard that this particular engine type has "no good history", but I do want to hear your opinion/ advice on what I can do to rescue the situation. Regards, reinhard@poczta.onet.pl
Apr 14, 2009 at 9:58 PM
DAVE H
  • 13,383 POSTS
you need to make sure the timing belt is fitted correctly and adjusted correctly and the timing will not slip !!
Feb 25, 2010 at 10:05 PM
