2004 Fiat Doblo BREAKS
2004 FIAT DOBLO
CHARMAC
Brakes problem
2004 Fiat Doblo Two Wheel Drive Manual
NEED TO PUMP THE BREAKS TO STOP, TOOK TO THE GARAGE WAS TOLD THERE WAS A BUILD UP OF OIL, THIS WAS UNCLOGGED AND BREAKS OK, 4 MONTHS LATER THE SAME HAS HAPPENED CAN I CLEAR THE OIL IF SO HOW OR IS IT A JOB FOR THE GARAGE AGAIN, ALSO WHAT NEEDS TO BE REPLACED TO RESOLVE THIS PROBLEM WITH THE BREAKS FAILING.
MANY THANKS
Sep 22, 2008 at 11:41 PM
  • 55,433 POSTS
When you pump the brakes, do they go down to the floor? if so the master cylinder needs to be replaced.
Nov 21, 2008 at 2:28 AM
